New sony laptop for xmas and connection drops with "limited" appearing in wireless strength box.
Other laptops in house are fine. My router is 8 feet away in same room.
Turned off power save etc. Did all the easy fix options to no avail.
If someone can post and paste a fix using EASY stuff for non computer expert like me that would be fabulous.
Most dissappointed.. my last laptop was 12 years old.. tired and so was getting myself a treat... I already miss its noisy fan as I never had this problem.
Connection can be restored by dissconnecting , turning on airplane mode then doing the reverse to reconnect.
help please.. contacted shop and they said this is a windows 8 issue and nothing to do with SONY so nothing they can do.
Solved! Go to Solution.
Hello!
for the problem : Wifi connection 'Limited' try this
https://ca.en.kb.sony.com/app/answers/detail/a_id/43725/p/48903,4990,74253,85577/c/65,67/kw/43725
and this
from the second url i tried the 2. Wake up your Wi-Fi Adapter and the 3. Enable Download over metered connections
until now everything looks fine ... i have 2 days to see the "Limited connection" ...
Hi iansythes you haven't said what Sony laptop you have but I would suggest checking if there are any updates available for your Vaio. Updates can be found by entering your Vaio model number into the box on this link.
hi
sorry i have the laptop number in battery compartment, the laptop is a.
svf1521a2ew hope this is the right identification number
Hello!
and this
