No Networking
profile.country.en_GB.title
NigelT_B
Visitor
No Networking
I've recently aquired a VAIO VGN-NR3-8E. Seems to work fine but won't connect to the internet either wirelessly or using an ethernet cable. I'm told there's a driver missing. There were no disc with the computer but I have tried to create recovery discs in the hope that I can replace whatever is missing - no luck there either. Can anyone suggest what I might do next - short of chucking it out! Thanks
2 REPLIES 2
nikkilim
Visitor
Hi. Check on the support tab and search for the model of your Vaio. There should be a section for you to download the driver.
Good luck. http://imagicon.info/cat/12-13/vbulletin-smile.gif
NigelT_B
Visitor
Hi. Thanks for taking the time to reply. Problem is though, that I can't connect to download anything. Would it be possible to download on to another computer (not Vaio)? Regards.
