Problem with my wi-fi conection at home
SOLVED
standi74
New
hi, I have problem with my wi-fi conection at home . when the router is close to pc no problem , but when i go to my room conection failed
1 ACCEPTED SOLUTION
Accepted Solutions
mikewest777
Explorer
Hey just read this post: http://community.sony.co.uk/t5/PCs-Accessories/SVF1421C5E-Wifi-connection-Limited/m-p/1258778#U12587...
The problem is discussed there and I think resolved there too 🙂
2 REPLIES 2
mikewest777
Explorer
There is a series of fixes for Wireless connections on this site. I had a few problems and followed these fixes and all was okay.
http://www.sony.co.uk/support/en/product/SVF1521N1EW/tips-and-solutions
Not sure this helps. But my connection was simply giving up halfway through lengthy downloads and this seems to have fixed it.
mikewest777
Explorer
