Sony Vaio Pro 13.3 SVP132A1CM VAIO CARE ???
RESUELTAS
TH3ORY
Hi all i cant get vaio care to be installed can some one please point me to the right direction please ??
Im really desperate here, i have got vaio care desktop installed i need just vaio care as it was working fine on windows 10 but i had to do a full system refresh..
i lost all my drivers the vaio care desktop 8 4 6 0516.. i've also got vaio care hardware diagnostic plugin, vaio control center, vaio cpu diagnostic, and vaio update installed.. Please note CPU dig and hardware dig do not work the options dont show up to control things like the battery at 80% charge only,,
even though that's some how enabled but i doesn't let me control it i can not set the fan to silent or other modes etc. can someone please point me what i need.. Oh i do have windows driver  package installed SFEP  11/15/2011 8.0.2.3 Thanks
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
Blencogo
Where have you downloaded the drivers and utilities from?
There is a Vaio Care for Windows 8 on the download website for your model along with the previously installed drivers here:-
https://www.sony.co.uk/electronics/support/laptop-pc-svp-series/svp1321y9e?downloads-num=93
When Sony tested Windows 10 on your Vaio, they only recommend an upgrade from Windows 8.1 with the drivers already in place using the downloadable ' VAIO Update for Windows 10 Upgrade tool '- so I'm not sure it is possible to get everything to work from a clean Win 10 install.
http://sony-eur-eu-en-web--eur.custhelp.com/app/answers/detail/a_id/81944
Ver la solución en mensaje original publicado
2 RESPUESTAS 2
Blencogo
TH3ORY
Hi thanks for the links that is where i  was downloading the drivers from ive mange to get vaio care battery care function working again thanks
