Stupid problem
SOLVED
profile.country.en_GB.title
James-Whitehouse
Visitor
Stupid problem
Ok so i have this really silly/stupid problem. I was playing World of Warcraft and my laptop kept freezing so i had to hard reset it, then when i tryed to start it up again it kept freezing on the VAIO screen, i found out that if i put pressure on a certain part of the computer it stops freezing (near to where the CMOS battey is) and starts loading so i did that for a while so i could Factory reset it and now it wont work at all and it just keeps freezing i thought it might be the CMOS battery failing but i have only had the laptop for about a year and 4 months i also thought it might be that i have a dead ram module.
Does anyone have a solution to this cause im really stomped and i really have no idea what to do.
I cant afford to buy a new laptop at the minute because im saving for University.
And i dont really want to sell my Supermicro 7046GT-TRF because im getting payed from hosting servers on it.
Please can someone help me?
Laptop
Sony VAIO VPCEF2E1E/WI
Chipset   AMD M880G Chipset
Processor Name   AMD Athlon™ II Dual-Core Processor P320   2.1GHz
Memory Size (GB)   4
Hard Drive Capacity (GB)   320
Graphic Card Name   ATI Mobility Radeon™ HD 4200 Graphics 1GB
OS Microsoft windows home premium 64 - bit
Desktop
Processor   Dual intel Xeon X5690 Proccessor 3.46GHz
RAM   192GB DDR3
Graphics   PNY Quadro 6000 6GB GDDR5
Hard Drives   6 x Seagate 3TB hard drive
OS   Microsoft windows Ultimate 64 - bit  (OEM)
Message was edited by: James-Whitehouse
1 ACCEPTED SOLUTION
Accepted Solutions
Blencogo
Hi James,
From what you say, it sounds like you have a hardware problem that is going to need an engineer to check inside for a poor contact.
You can try removing and re-seating the RAM but if that does not help you will need to contact Vaio Support or one of Sony's Service Partners for further advice.  There is probably not a quick fix.
The telephone number for Vaio Support is 0905 0310006 during normal office hours.  You will need to have your Vaio's Serial Number available.
:thinking:
2 REPLIES 2
James-Whitehouse
Visitor
So, i have it working at the minute but as soon as i take the weight off of the left hand side of the laptop it is freezing. can someone please tell me what i can do to stop this?
Blencogo
Hi James,
:thinking:
