- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
VAIO keeps freezing!!!
HI guys,
my laptop is 2 years old, i've been having a problem with it whch has gotten worse over the last couple of moneths.
when i watch videos online it justs freezes, it sometimes says graphics driver didn't respond and was restarted..the laptop also heats up could this be the problem?...this problem has gotten worse, i have checked for updates in vaio update but there isn't any driver updates. what can i do to resolve this problem?
Could someone help me please?
thanks
Shan
vaio VPCEB1E0E
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
have you thought about a fresh windows installation?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Sometimes, that actually works. Having a freshly installed Windows does the trick.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You should try running the windows check disk utility to locate bad sectors and recover readable data.
_______________
Life is too serious to be taken seriously
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi SRaza94,
High temperature may possibly be the problem. Can you download either PC Wizard or Core Temp and let us know the processor temperatures when viewing videos online or carrying out any processor intensive activity.
http://www.cpuid.com/softwares/pc-wizard.html
http://www.alcpu.com/CoreTemp/
Rich
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
hi @katherine... i tried this but there were no bad scetors...any thing else??
Message was edited by: SRaza94
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
this was whilst watching a youtube clip, i do think its an overheating issue because when it cools down slightly it carries on working.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Shan,
Those temperatures are well within acceptable limits. If you constantly had temperatures of between 75 and 80 deg. it may have explained the problem.
There is a graphics driver update available for your model and if you have not already done so I suggest you install this.
http://www.sony.co.uk/support/en/product/VPCEB1E0E_T/updates
Rich
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
thanks rich...are you sure the drive update is for my model? no updates come on in vaio update, and my model is VPCEB1EOE and doesn't mention /T.
just want to make sure it's for my model.
thanks again
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Shan,
There are two VPCEB1EOE models listed on the support site, a /T and /WI - this just refers to the colour, but you should be able to find your exact model reference in Vaio Control Centre.
That said both have the same update available. I can't explain why Vaio Update is not listing anything unless you already have the update installed.
Rich
