VAIO KEYBOARD not working
profile.country.IE.title
binoys75
Novo
 Hi I have sony vaio laptop,windows 8 Model name: SVE1512B1EW and the keyboard is not working properly. I cant type letters & numbers and even the back space is not working. What should I do?
4 RESPOSTAS 4
jumpsuit
Hi there and welcome to the Community :slight_smile:
Firstly a couple of questions for you:
Was it working fine previously?
Have you installed any recent updates e.g. Windows 8.1?
Also have you tried contacting customer support?
cwmffrwdgj
model sve1512b1ew
I recently updated windows 8.
The keyboard and touch pad no longer work
I went into system recovery and recovered the system. However now the system is recovering i am in the region and language section for which I need a keyboard and pad to select and go to next.. The keyboard and touch pad do not work how do I move on to fully recover?
I have no recovery discs
leijiao
try to find some external usb keyboard and mouse probably is the easiest way... looks like it is some driver issue with windows 8
Nobody-in-particular
Participante
Hi yes an external keyboard should allow you to complete the instalation but it sounds like it could be a hardware issue, was the keyboard working before you ran the recovery?
