Vaio VPCSA3T9E Replacement Disk Advice
SOLUCIONADO
chiver
Hi,
I'm trying to find a replacement disk for a Vaio laptop. Doesn't appear to be a standard SSD, mSata or Micro SSD from what I can tell. Note the pins in the photo. I have some spare disks, nothing similar. Any advice appreciated.
Product - VPCSA3T9E, Model - PCG-4121DM
Disk Connector - VO30_MP_SSD_1CH1CONN_FPC-240
1 SOLUÇÃO ACEITE
Soluções aceites
Blencogo
Hi @chiver @and welcome.
I have the VPCSB SSD Vaio. Should be the same.
These Vaios are fitted with a 1.8” MICRO -SATA SSD (MZRPC128HACD-000SO) which is connected to the Vaio with the microSATA ribbon V030_MP_SSD_1CH1CONN_FPC240.
Something like this
https://www.ebay.co.uk/itm/Laptop-Internal-Hard-Drive-Solid-State-Drive-Disk-Min-SATA-1-8-SSD-128GB/...?
You can try to source a bigger micro-SATA SSD but this is not easy and you may have to order from China.
Alternatively, you could try replacing the ribbon with standard SATA ribbon and buy a caddy for the standard SATA SSD. I think you need the FPC239 SATA ribbon. Try part # A1833020A or A1816281A.
Good Luck!!
6 RESPOSTAS 6
jumpsuit
Hi @chiver  and welcome to the Community :slight_smile:
Its probably worth you getting in touch with EET Europarts (Sony's official parts retailer) about this.
Sony Customer Helpline: +44 (0) 333 241 9271
If they don't have one they may be able to suggest somewhere.
Failing that it may be worth checking Ebay for a 2nd hand unit  or even a unit
designated for 'spares and repairs'.
Find this component online:
024-0001-8530-A
chiver
Hi @jumpsuit ,
Thanks for the reply & the welcome. I'll give them a call.
The issue I'm having is I'm not sure what disk would be suitable for this connector, a standard SSD doesn't fit. I'll likely need the part number for the disk, or another suitable connector for a standard SSD.
I'll let you know how I get on.
chiver
Hi @Marino.Manolo ,
That part number is for the connector that I have in the image - 024-0001-8530-A
Do you have the part number for a suitable disk that would fit that connector?
Thanks
Sorry, I did understand...
I think that you need is this (ODD, Optical Disk Drive):
https://uk.eetgroup.com/i/A1827261A-Sony-ODDPSN-BCQL-9.5-242BFS
Edit: Hard Disk (SSD) and not ODD
Blencogo
Something like this
Good Luck!!
