WEB CAM
mrjingles-suzuki
Visitante
WEB CAM
How do i connect my sony PC120E camcorder to windows messenger so i can use it as a web cam. my computer is RX-306
2 RESPOSTAS 2
smsmasters
Visitante
u cant use that camcorder as a webcam. it is not designed as a webcam. :angry: :angry:
Floandal
Visitante
It is possible to connect most DV or analogue camcorders via firewire or analogue connections and use as a webcam, using specialist software.
One allowing firewire connection called "WebcamDV" here ---
http://www.orangemicro.com
One which allows you to connect via the analogue-out connection to a TV-card ect called "CUseeMee ---
http://www.cuseemeworld.com/download.asp
If the tape is left out of the camcorder, it prevents the cam going into standby mode.
Alan.
