Hi
I have tried contacting Kodak (no help really), and looking online... but with no success. I think the problem lies with either this laptop (because it worked on my older laptop), with Windows 7 (as the other laptop had XP)... or with the anti virus not letting either the CD or internet download... load. Please help as this is for my daughter to use for her GCSE work. Thanks (in advance). Regards
Dave
go to network and try to find from there the printer. you will see the option add printer!!!
Hi Dave,
Can you give us the Vaio Model: -
and also the model of the Kodak printer.
The Vaio is VPCEA2C5E and the printer is a Kodak ESP5210
Tried that... it cant see the printer. I can, but the computer cant.
Try downloading and installing the latest Windows 7 Driver and Firmware for the ESP 5210 from here: -
Have a look here for WiFi connection instructions and FAQs: -
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=13637&pq-locale=en_US#wg12_1
Are you connecting via a network wireless router or direct from Vaio to printer?
I will try your links thanks. I am using the router to connect to the printer... I think.
D
Good Luck!
It sounds like you're experiencing difficulties with wireless printing on your Windows 7 laptop, possibly related to antivirus software blocking the installation. Here are a few steps you can try:
Hopefully, one of these steps will resolve the issue and allow your daughter to use the printer for her GCSE work.
