- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Sony Inzone buds not working with Telegram in Bluetooth Mode
The application does not use the microphone and speaker of the headphones for calls when i'm using Bluetooth. I can only view multimedia, but when I receive a call, the application switches the sound to the phone's speaker and microphone. In other applications everything works as it should. I set all permissions in Settings, and also, on web.telegram all also works fine, and only in App I have troubles.
I have another Earbuds, but it's the regular BT without LE- audio. They work fine as they should. So the problem is only with Le Audio, and only with Inzone Buds
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
UPD: Phone is Samsung S23 Ultra with all latest updates
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hey @Demize
It seems to me like an issue with the Telegram app itself. I'd suggest that you contact their support team, since the headset is working with other apps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Unfortunately, it turned out that the only place where the headphones work is WhatsApp. All other messengers, such as Telegram, Viber, Discord, Facebook - they do not work anywhere. It seems to me that I have a defective unit, since it constantly disconnects and reconnects. I tested the headphones on two phones and both had the same problem.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@Demize Try to reset and initialize it, update the software Version 02.000.002. If still not working, you need to contact the support team.
