Micro sd card
SOLUCIONADO
Paul18
Visitante
Micro sd card
I recently bought an xperia x. I have just purchased a 64gb micro sd card. I've fitted it into my phone but it doesn't show up. The transfer files from internal memory to sd card option in the settings is greyed out. What do I need to do to get it to show as an additional memory??
1 SOLUÇÃO ACEITE
Soluções aceites
Paul18
Visitante
Success. Swapped for a new sd card. Put it in the phone and when I switched on a drop down box told me to set up memory card. Thanks for the assistance today
12 RESPOSTAS 12
profile.country.RO.title
_alexdon_
Try to restart your device.
alexdon
Paul18
Visitante
Restarted it about. 4 times
_alexdon_
Have you inserted it correctly? Did you check the card in a PC?
alexdon
Paul18
Visitante
Hard to insert it incorrectly when it only goes in one wayway. . I'll try card in my pc when I get home
_alexdon_
Keep us updated.
alexdon
Paul18
Visitante
Will do thanks
Paul18
Visitante
Is there any compatible issues that you know of or should I be able to use any make, size Micro card. I'm thinking of swapping the sd card at the shop I bought it from on the way home from work
_alexdon_
The device is relatively new, so I think up to 200GB should be just fine. If it's a Sony/Samsung/Sandisk, that should be ok.
alexdon
Paul18
Visitante
It's a SanDisk that I'm having the trouble with. Hopefully Its just a faulty sd card
