my sony headphones with wired
SOLUCIONADO
profile.country.RO.title
Cazacioc
Novo
I can no longer use my Sony wired headphones on a Sony Xperia XZ Premium. Why ?
1 SOLUÇÃO ACEITE
Soluções aceites
Cazacioc
Novo
Thanks for the advice. I identified the problem. It was the phone case that prevented the headset jack from making contact.
6 RESPOSTAS 6
IamNic
Hello @Cazacioc,
maybe pocket-lint has accumulated in the headphobes port, preventing the headphones to fully make contact.
You should be able to pull it out with a thin sewing needle if you bent the tip.
- Nic
Cazacioc
Novo
IamNic
Hello @Cazacioc,
glad to hear you found the root cause.
May I know which case you use(d), so I can warn other people from getting it.
- Nic
Cazacioc
Novo
Hello @IamNic ! I protect the phone with a case. Always. The problem belongs to me because I had to insert the headphone jack more carefully. Thank you for your interest in this issue.
IamNic
Hello @Cazacioc,
ok, now I understand - it was not an issue with how the case was designed around the port - you just didn't press the connector into the port correctly.
- Nic
Cazacioc
Novo
The edge of the cover in front of the port easily blocked the port and the headphone jack did not reach to make the complete contact. I pressed and the jacket went to the end and the headphones worked
