Wifi uses battery when WiFi is not used
Y69
Visitante
Battery usage show wifi use.but i am not using wifi
Topic edited by Rickard
14 RESPOSTAS 14
Uliwooly
@Y69
Is the WiFi on?
Y69
Visitante
no wifi always off
NeoBeum
Entusiasta
Make sure location services aren't using Wi-Fi
Y69
Visitante
hey NeoBeum you are right but i am confused.why location service use wifi without wifi signal
NeoBeum
Entusiasta
Triangulation. Some services ping a hotspot and asks for its location.
If you want to monitor radio get NetGuard or something, then you can find what's doing it
Y21
Visitante
so what i am doing
Y69
Visitante
hey NeoBeum so what i am doing?
NeoBeum
Entusiasta
What¿
Y69
Visitante
This problem create when device software update to (v. 39.2.A.0.374) on 02 Jan 2017 before software update no wifi problem
