Can’t find battery for Cybershot DSC-RX100 M3 . Duracell direct battery does not fit.
SOLUCIONADO
Derek.
1 SOLUÇÃO ACEITE
Soluções aceites
Derek.
Good afternoon  D
Please cancel the above post
I was quoting the battery number   from the wrong camera.
The battery from Duracell Direct works fine.  Just got to find instruction book to charge the battery
i am too old!!!
You can order with confidence  from Duracell Direct (£16.99) in UK
Regards
Derek
5 RESPOSTAS 5
Showdivad54
  1. Hi. I had the same problem, I suspect your original battery is the  "info lithiam" version. I believe sony sells them for around £80 Regards D
Derek.
Thanks D for your reply.
I am online trying to find the battery on the Sony website- failed completely. No  list of batteries
The  £80  Sony battery what was the  approx date for this?
MY existing Sony battery is a NP-FR1 which Duracell Direct said was obsolete. The battery that Duracell  supplied
had 4 contacts instead of the 3 on the existing battery. I rejected this battery on visual inspection only.
Regards
Derek
Derek.
Good afternoon  D
i am too old!!!
Regards
Derek
Showdivad54
Hi. I'm away from home at the moment so can't check the battery number, but I know the battery from my modern Alpha A65 fits my 22 year old sony DSC-S70 . I tried a Duracell it didn't work because it wasn't "info lithiam" have a look at the Sony Alpha a65 battery images. (The Duracel worked in the Alpha a65)
Showdivad54
No worries Derek. Glad you found the solution. I think the battery charges in the camera.
Regards David
