4OD no longer listed on BluRay BDP-S3100
SOLUCIONADO
webmail7
They seem to have fixed the BBC iPlayer app, but now 4OD has disappeared from my list of apps. It worked fine and I'd been using it a lot. Now it's completely gone - anyone else with the same issue?
1 SOLUÇÃO ACEITE
Soluções aceites
Anonymous
Não aplicável
Hi there
Reading back on the original question and answers, I think I probably miss-read this one to be honest.  I probably mis-took 4OD to mean 5OD.
So to clear this up - 4OD (and ITV Player) has not and is not available on the Bluray players.  So that is the reason why the app is not available.
Hope that clears this up.
6 RESPOSTAS 6
Anonymous
Não aplicável
Hi there
Try turning off all your bluray player and router for a couple of minutes, then switch it on again.  Hopefully it will then detect correctly.
webmail7
Thank you for the tip, Qinnicus, but I tried that and still no 4OD back. Did you have the same problem?
Anonymous
Não aplicável
No, not experienced that exact problem (but then again, I dont have a dedicated blu-ray player, my PS3 works good:smileyhappy: )
Generally rebooting normally solves alot of problems - considering that no one else is reporting the problem indicates its isolated to you unfortunately.
What I should have included, is a couple more steps if rebooting player and router doesnt resolve the problem
The next thing you can try, is to perform a Network Update from the settings menu.  If that fails, you may want to consider a factory reset of the bluray player itself.
Miketrevor
Novo
Hi, did you manage to fix this problem? I would also like to watch 4od on my BDP-s3100, but haven't got the app.
Regrds Mike
Anonymous
Não aplicável
Hi there
Miketrevor
Novo
Ok thanks for the reply.
