BDP-S390 - SSL Auth error since firmware update
SOLUCIONADO
tombates2
Hi guys,
I'm having issues accessing a particular web service since firmware update - BBC iPlayer.
Netflix still works fine.
Can access iPlayer but when I try to begin a stream having selected a program, the following display shows:
SSL Alarm Display
The security of the target peg cannot be confirmed. An error has occurred during server authentication
I've tried manually setting the IP of the player, and connected succesfully but that didn't solve the issue. I've also tried a reset of internet and network settings and reinput the wireless details etc... still no joy.
Does anybody have any advice - and if not, is it possible to roll back to the last firmware version? Seems like Sony has just broken my Bluray player :slight_smile:
Thanks!
13 RESPOSTAS 13
profile.country.en_GB.title
Catmambo
Participante
Great, glad its working. Could be one of a number of things, but software not hardware. SSL as you may know is a security protocol used to secure connections from interference, so likely something in the chain wasn't handshaking properly with the device. So Factory resets normally flush these kind of issues. Odd it had to be done twice, but good its fixed...
thanks
bagman_66
Novo
I have to do a factory reset every few days. It drives me crazy. I have contacted the BBC about it so will see what comes of that.
wnstnybt
Novo
1. go to the internet browser on the BD device, 2. enter url of the site that is inaccessible due to ssl alarm e.g. www.youtube.com; the 'security of target page cannot be confirmed an error has occurred during server authentication' will display but with an option to turn off the ssl alarm. 3. Select turn off option. 4. Now go back/exit the browser and open the YouTube app. DONE and SOLVED! No need to reset internet settings.
John99909
Novo
I have the s490 and have the exact same issue. Running the latest firmware. The resetting to factory default isn't resolving the issue either.   Please help.  I just need iPlayer working.
