I have seen this problem on the forum but suggested remedies have not worked.
This morning I found my HXD995 stuck on update. No response from controls and when switched off at socket reverted to update on reconnection. By switching off at socket and instantly pressing on at reconnection I managed to switch on recorder. However all digital channels failed to work. I tried rescanning which found the channels but still could not tune in. The digital guide was empty.
I checked the firmware which is 1.24. I then reset the recorder but made no difference. (I rechecked the firmware after reset, still shown as 1.24)
I tried update but again it stuck. Also I note when I change digital channels (none of which worked) the number of channels I can check is very few, refuses to try higher numbers.
I would appreciate any help on this. Thanks
Andrew
I have exactly the same problem starting last night. I have retuned the device successfully but no info in the EPG. Up and down using the "prog" button goes to the wrong channel. Some channels show the programme for a second then shut off. The device did not fully respond to the remote control. Powered off by holding the power button for 5 seconds.
Is this coincidence?
Dubbing to DVD and recording on from "line 1" working as expected. Programme list as expected.
Further to my query I find everyone has the same problem!
Clearly a duff update.
Over to you Sony...........
Andrew
I have exactly the same problem, machine stuck updating, channels no longer appearing. Tried factory reset and updating firmware using 1.24 download, this got stuck also.
Please sort this out Sony, this is an absolute disgrace and I will be forced to by a new recorder if this is not resolved in the next few days.
Hi All,
before posting any further comments please read this thread
