Sony DAV-DZ330 keeps forgetting speaker calibrations
SOLUCIONADO
profile.country.en_IE.title
Mar1tin
Novo
Hi I'm new forum, I purchaced a sony dav-dz330 and I think it has a couple of bugs most of which there is away around. But one that I'm finding very annoying is, It keeps forgetting the speaker calibrations settings. I've tried to pinpoint what was causing it. I'll give you an example I started to think it was to do with shutting the system down when it was ih USB mode, so I turned the system of in DVD mode, left it pluged in all night, came back next day turned it on and the settings were still there, so put the system in USB mode turned it of and on again and the settings were gone. I taught I nailed it but tried to do it again and it wouldn't do it. Its a bit annoying. Does anybody else have the same problem or does anybody know will there be an update to fix the problem? Thanks in advance
Marcas (2)
1 SOLUÇÃO ACEITE
Soluções aceites
Anonymous
Não aplicável
Hi there
The only thing I can think of is to perform a "cold reset" :
If that doesnt work, im afraid that you will probably have to contact an Authorised Sony Repair Centre to have this fixed.
2 RESPOSTAS 2
Marcr1757
Novo
I have this problem too but can't find a solution anywhere!
Anonymous
Não aplicável
Hi there
