Have you tried a software repair until now?Because I told you before but you did not tell me if you repaired.
Just visit a sony service.
I also have this problem
Sony Support does not help for this problem than what to do.
Why?
Try the following:
1) Go to Tools (setting) - > “Xperia” >“Internet Settings” click ACCEPT to install the Internet & MMS setting.
2) After update, Manually Switch off and On the phone.
me too have this annoying probelm, kindly if anybody could solve it , tell us
Me to, I have the same problem. I try to reset at the factory setings twice, format the memory card, and phone memory, after a while the problem is back. In this moment I give him this software repair... will se after.
Ok, from now(couple of hour since) the problem was solved with "update service". Will see, last time past factory reset, and format all, the problem stay's away about a week.
Keep us updated.
