Bad picture on Sony Bravia KDL-32EX301U
RESUELTAS
rogerb1970
Nuevo miembro
I bought my KDL-32EX301U in November 2010. Since then it has worked perfectly, up until an hour ago when the screen suddenly went like this:
http://i265.photobucket.com/albums/ii239/rogerbee/DuffTV_zpsa9e95c80.jpg
That is of course a freeze frame and the vertical ghosting also scrolls. I tried both unplugging and retuning but to no avail. Obviously the TV is long out of warranty, but, I was just wondering if there was anything I could do. I don't really want to fork out for another TV just now, but, if that has to be the case then so be it. Any input would be greatly appreciated
CHEERS!
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
rogerb1970
Nuevo miembro
Thanks for your reply,
It happened everywhere on everything, a reset couldn't save it. It's had a good innings I suppose, but nothing lasts forever.
A new TV it is then....
CHEERS!
Ver la solución en mensaje original publicado
2 RESPUESTAS 2
Anonymous
No aplicable
Hi there
Yes, not a nice picture at all!
Is this happening on ALL inputs and devices connected (ie dvd/bluray player) or is it just Freeview?  Can you test this out?  If its just Freeview, I would suggest looking at your aerial cable (or aerial).
If its all other devices too, try doing a factory reset (a long shot to be honest).  If that doesnt fix it......Well, you know the answer.
rogerb1970
Nuevo miembro
CHEERS!
