I have a Sony Vaio S series laptop and the screen is completely shattered and i can't see anything.
I was wondering if someone could tell me the keystrokes needed to enable external display from the BIOS and include a screenshot of the BIOS. I already can operate the normal windows on the external display but I want to change the BIOS settings so i can reinstall widows 7 and prepare my laptop for the upcoming Windows 10 update.
The model number is: SVS131B12M
The product name is: SVS1311N9ES
Any help is appreciated.
Thank You
It's fine I don't need any help.
I removed my screen and I was able to enter BIOS and updated to Windows 10.
Hi jalp_14 and welcome.
I don't think it is possible to view on the external monitor until Windows loads.
What are you trying to change in the BIOS?
I am having same problem, can you let me knowhow to remove screen ? Appreciate your help.
