- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
Desktop PCV-LX1 - removal of casing
Hello!
I should be very grateful if someone would advise me on the method for removing the casing to access the hdd as I do not have my manual to hand.
Regards
Ritchie
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
There is a manual available to download at the following site:
ftp://ftp.vaio-link.com/pub/Manuals/Desktops/LX1/LX1_H_EN.pdf
Its in english, and the section you want is on page 69. Its the bit about removing and installing memory - but it shows you how to get the cover off - whch is what you want to know.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Go to Solutions Room for the answer, but sort version; Finally the dudes @ Sony (Love hate kind of thing) have got back to me. I have to max out my systems memory from 512MB to 1GB (Thank god memory getting cheaper)
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Ritchie, according to http://reviews.zdnet.co.uk/review/9/2/246.html you need to unplug the power plug and unscrew the single screw in the power socket, then the case will slide off.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
The screw is actually just to the side of the power inlet not inside the power socket (see p.69 of the manual as mentioned before).
I don't think electrical safety would allow the screw to be inside the actual power socket
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Jaan, thanks for the clarification.
I did not see your earlier post with a link to the online manual. Of course that is the best reference.
