Hi I have a VAIO SVE1511P1EW laptop but the cd drive isn't working.
There is a little triangle error sign next to the CD/DVD drive icon.
Could you please assist me on this problem?
Kind regards
Hi javz20 and welcome to the forum.
Do we take it that the warning triangle appears in Device Manager? If so is there an error code under properties? This may give us a better idea of the problem.
Unfortunately CD/DVD drives are probably the most unreliable hardware component of any computer due to the mecanical nature and as you have probably gathered from this thread problems are difficult to identify. Have you tried a variety of CD/DVD media in the drive?
Rich
I have a problem
Hi @christopherjhnsott70 and welcome to the Community
Can you give us some more information on what problem you're having?
