sorry, i forgot to say that before not reading any discs the record now! program showed this error message:
Sense: 03 ASC: 0C ASCQ: 00 (Command 2A)
Px.dll: 2.0.60.500
pxdrv.dll: 1.1.23.0
pxmas.dll: 2.0.60.500
PxWave.dll: 2.0.60.500
PXWMA.dll: 1.0.0.3
thanks in advance for any help
Hi anibalstereo and welcome.
The error message is for a general write error or buffer underrun and usually means that the type of disc being used is 'incompatible media'. Have you tried a different make of discs?
The files quoted are not specific but are usually associated with WinAmp or Sonic Record Now. Have you updated either of these recently?
Another old favorite causing this error is Roxio. Do you have any of their Easy CD/DVD Creator software installed?
Sorry I can't be any more specific but you could try reinstalling these programs if you have them.
Hi blue_belle and welcome to Club Vaio.
Sorry you've not had a very good start!!
Can you just check in Device Manager to see if there are any yellow warnings with ! or ? against your DVD Drive.
Start -> Right-Click on 'My Computer' -> Properties -> Hardware -> Device Manager and expand DVD/CD-ROM Drives.
Do you have a yellow warning? If so double-click it and tell us the error code.
Ty for reply, I already checked that and there is nothing listed at all regarding DVD drive or anything else. I have since tried again - recovered, installed updates and its gone once more, so I cant get any further.
thank you, blencongo for your message. i don´t have winamp or any roxio program installed on my computer. moreover, a few minutes before this thing started, i was burning cds without any problem.
now, it doesn´t recognize empty cd/dvd´s, but reads everything that i´ve recorded before.
yesterday i´ve tried to move the metallic block, but nothing changed...
any other idea???
thanks!!!
Hi everyone,
i have a problem with my DVD-Drive Pioneer DVR-K16M in my Vaio FE11S. I installed the latest driver on Vaio-Link-Page Version 1.10, but my problem, that during burning DVD's (doesn't matter if "plus" or "minus") often the process stopps before 100%! When i burn a Movie and it stopps before 100 never the less i can play the Movie in my TV-DVD-Player (till the point where the burning-process stopped). I use the latest NERO 7-Version. Any Ideas how i can solve my problems? Should i ask the Vaio-Support?
More Informations about the Setup: Windows XP SP2, Updates from Winboard Version 2.22!
Thanks a lot!
Schrambo
Sorry, but my english is not very good....
When I saw your info, I thought you may be able to help me if it's not too much trouble. My laptop (Vaio vgn-sz1hp/b) has just come up with the following message -
System32\Drivers\Ntfs.sys is corrupt or missing
Is there any way out of this without using the recovery disk; I assume that if I do that, I lose all my data - that would be disastrous.
Thanks
Keith
Hi Keith,
Welcome to Club Vaio,
You should find a copy of the ntfs.sys file in C:\WINDOWS\I386..
Copy the file from C:\WINDOWS\I386 folder to the C:\WINDOWS\system32\drivers folder..
Hi. When I try to double click my DVD/CD Matshita writer, I get "F:\is not accessible. The request could not be performed because of an I/O device error". Had a look at this on MS website but can't work out which IDE channel the burner is on. Does anyone have any ideas?
Many thanks.
Hi lizmac,
Your CD/DVD drive should be the secondary IDE Channel..
Have a look at this MS solution..
