Contacts disappear
SOLVED
DrOnline
Visitor
Contacts disappear
Hi,
I just got the Sony Xperia Z3 about a week ago. First time using Android. Happy so far.
But there is a serious problem: My contacts have repeatedly simply disappeared from the phone. It happened again just now. I clicked the contacts icon, and I could see the contacts rapidly disappear, and now I am only left with:
* ICE - In case of Emergency
* Myself
What's going on?
65 REPLIES 65
profile.country.RO.title
_alexdon_
If you try it,keep us updated.
alexdon
Drakul
Visitor
This is SO WRONG IN MANY LEVELS. when you an mp3 player, you put music into it;when you have a phone you add contacts into it. My point is... Contacts are basic on a phone. You can't just have errors and have randomly all contacts disappeared. I run work and personal life from this phone. Contacts being erased is never an option.
Is there somewhere I can place a serious ticket about it? Is just not right in any level.
Things like that would say sony is not ready to make phone software just yet
stockyvillage
Contributor
The easy solution is back up your contacts on your google account.
Drakul
Visitor
Of course the easy solution is to back up. I know that man. But a phone should not erase the contacts. The easy solution to that (if it is a common error) is to Change brands
stockyvillage
Contributor
Repair your phone using PC companion.As your problem is software related
Drakul
Visitor
Will that erase my info, apps, messages, etc ?
stockyvillage
Contributor
Yes Drakul it would so back them up first
Drakul
Visitor
How do I repair it? Sony companion just freezes and stops working.
Kari_79_99
Visitor
Thank you Thank you Thank you Thank you this is the second time all my contacts had disappeared. First time I thought I'd accident my deleted them.
kishoravali
Visitor
Same thing happened to me yesterday. and i know that i did not delete them by mistake. i tried force closing and restarting the phone. can someone tell me if something works?? Please!!!
I cant belive this. this is my 2nd sony phone!
