отмена
Отображаются результаты для
Вместо этого искать
Вы имели в виду:
firmware update to v5.457
Jacko1966
Новый
Hi, I am trying to find this firmware update for my  sony kd 65xd8599 and note it’s no longer available on the download site. Is it possible to have this sent to me via email please?
16 ОТВЕТ 16
symboliser
Новый
Are the zip files and links compatible for all Sony Bravia 2015/2016 Android TVs? I've got a KD-43x8305c that's been on firmware 5.435 (2019) forever. If 5.457 (2020) has improvements I'd like to install it. If the previous packages work for my unit I'll use them but if I need a specific pkg for my model I can wait until someone posts it.
bikerblue
Участник
Hi,yes you can use this file in your model.I found it hasn't cured the
locking up problems I have though.Every couple of weeks I have to do a
factory reset as everything starts running slow then it's ok for a week or
so.It sounds typical of a software issue but no one else seems to be
having an issue
Shaz723
Исследователь
Hi, can you please share the software for KD43X83 09C, thanks
Shaz723
Исследователь
Can you please share the software for KD43X8309C, thanks
bikerblue
Участник
Hi the link should be in my post somewhere
royabrown2
Герой
@bikerblue
Your latest post says ‘this file’, but it doesn’t include a link 😢
@Shaz723, look further back up the chain of posts for @bikerblue‘s link.
Merry Christmas to all! 🎄🎅🏻🎄
sonysony1122
Исследователь
Hi can anyone help out with the latest firmware for the kdl-65w850c please? I believe its  version 6.827
