I have a Bravia TV and decided to explore Freeview as I had never found or used it.
I discovered it but when I go to TV guide now it comes up in black and white with no BBC channels.
how can I get the TV back to showing live TV and the guide in colour once again?
I find this infuriating.
@chrissymx5 wrote:
Sent from my iPad
Er…. Was there supposed to be some content there?
No you don't need to press Enter or OK.
After making the selection between TV and Live TV & Catch Up the TV automatically goes back to
the Settings> Channels & Inputs menu, from there you come out of the Settings menus back to TV broadcast.
Then press the TV button on the remote control to affect the change to the selected "TV app for Digital"..
Your post has got absolutely nothing to do with the question asked on a post that is over 8 months old.
